8n oil leak from proofmeter cable
Fwalton91
New User
Hey yall working on a Ford 8n tractor. It had the side mount distributor. It is leaking oil from the proofmeter/tachometer cable. Ive tried rtv and then it will leak from where the cable is put together. Ive tried two different cables. There has to be something i am missing. Should there be oil coming out of the back of the governor where the cable attaches? Thank you for your help.
I will check that, thank you for your response. Do you know how much oil flows through the governor? Or if there is a seal on the back of the shaft in the governor? Thanks
