Company Logo (800) 853-2651 Shop Now
Stuck valve guides
Jim in LA
07-21-2021 21:15:25
I finally got the last two valve assemblies #1ex and #3 ex out of my 8n block. Was able to get #1 out with $100 valve spring compressor to dismantle the valve, tap the guide down to get the retainer clip out and then drive the guide out the top. #3 required Dremel and cutoff wheel and cutting the spring into multiple pieces and ruining the guide driving it out but I am going to replace entire valve train anyway.
Hobo,NC
07-23-2021 05:12:24
 Re: Stuck valve guides in reply to Jim in LA, 07-21-2021 21:15:25
And don't forget to plug up holes so the keepers stay out of the oil pan...
Den N Ms
07-22-2021 02:06:57
Jim in LA, You could have just heated the springs with a propane torch to relax them and remove the keepers.Since you were going to replace them anyway.
The easy way to remove em.
Today's Featured Article - A Lifetime of David Brown Tractors - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
Latest Ad: Gemmer hydraguide 954 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
