What size wire should go from the starter button to the little terminal on the solenoid? Is bigger better? After I reworded the 8n and tried to start it, the first time it cranked right up. Second time the starter got stuck and would not disengage. Today it tried to crank but I noticed the solenoid smoking from the little terminal in the back. I changed the wire on the push button as it looked like it had some issues. I had a hard time getting the little terminal tight with just the crescent wrench but it is hard to get anything in the tight space. My guess is a loose connection? Wire got hot and solenoid was smoking from the connection.
