SlowCredit
New User
1950 - Starts first crank every time. Runs like a top. Gets hot, stops running after 30-45 min (depending on load). Restarts when cooled down.
Replaced coil and condenser - no change. It's 12V - I didn't do the change, it's been solid the 2 seasons I've owned it.
Reading old posts, looks electrical - not sure what's next. Looks like other culprits could be
Ignition switch (replaced last year - low probability, but it is a cheapo switch)
Thermostat
Gas tank cap/vent (can check this next run)
Water pump (will peek in on flow next run)
Anything else I should be looking at? Hate to shoot the parts cannon at it, but most everything could stand to be replaced anyway. . .
Thanks!
Slow
Thermostat
Thanks!
Slow
