52 8N starts right up and runs great in all speeds 40 psi startup
working 30+ no lower then 20 psi warm idle. No smoke at startup.
Working faint tailpipe smoke.After sitting at idle, throttle up and
blue smoke is very obvious and goes back to just a trace when I go
back working with a blade on the driveway. It takes a few projects and
#2 plug fouls, clean it up runs fine no misses.It is using a good bit
of oil even seems to be liquid oil at the end of the tail pipe. No blow by none.
