Re: Gaskets and sealants in reply to DonTheNewby, 04-07-2021 17:03:37
It all depends. As Bruce indicated different things for different seals. It also depends on the situation.
For instance, the book only specifies using a gasket on my governor. However, the governor flange is warped, so it doesn't seal with just a gasket. I used a thin bead of Ultra Black RTV on it and it doesn't leak a drop.
I've always tried to use little or none on the sealants. Sometimes you just need a little dab to hold a gasket in place. RTV can be your friend but people tend to get carried away. What most don't see is the big globs that are on the inside of what they sealed. I've seen the globs break off and clog oil pickup screens and radiators.
Today's Featured Article - Oliver 4340 Plow Setup - by ShepFL. How to properly setup your Oliver 4340 plow plus many tips and pointers that may apply to many other brands of plows as well.
... [Read Article]
Latest Ad:
Would like to find hay table for a John Deere 700 or 750 grinder mixer
[More Ads]
