Company Logo Shop Now
Ford 2N PTO
JJUK
04-05-2021 20:16:20
Just wondering if newer pto shafts would fit my pto. I looked at my pto and it has a hole through it. But I know the new ones have the sleeve you pull back to lock it. Looks like mine just has the shear bolt connection
JohnnyHville
04-06-2021 14:31:10
 Re: Ford 2N PTO in reply to JJUK, 04-05-2021 20:16:20
Sounds like you might be talking about the overrun coupler?
If you have the original PTO shaft it is 1 1/8. The only OCR I know of for 1 1/8 is the one with the roll pin through the pto shaft. If you want the spring sleeved ocr, you need to convert to a 1 3/8 pto shaft. Also, the newer implements use the 1 3/8
The kit on site that comes as a complete preassembled unit with bearings, screw on cover, and all. It is exceptionally easy to switch out. Unless something is goofed up on your splines, maybe a 15 minute job.
Den N Ms
04-05-2021 20:52:34
JUK,You can find one right on this site.
https://www.yesterdaystractors.com/Ford-2N_PTO-Shaft-Conversion-Assembly_9N70038.html
JJUK
04-06-2021 06:45:09
 Re: Ford 2N PTO in reply to Den N Ms, 04-05-2021 20:52:34
Thank you
Today's Featured Article - Oliver 4340 Plow Setup - by ShepFL. How to properly setup your Oliver 4340 plow plus many tips and pointers that may apply to many other brands of plows as well. ... [Read Article]
Latest Ad: Would like to find hay table for a John Deere 700 or 750 grinder mixer [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
