I have a 1942 9-N Maybe 2-N -- My dad bought it new and always called it a 9-N. It has never spent a night outside--always shedded. It has the SHERMAN step up transmission. It is the cable unit with the big round black bulb. The tractor was overhauled 50 years ago and used very little since. I use it on a rear discharge finish mower. Here is the question--after that overhaul the Sherman never worked again--the Ford dealer said the Sherman was bad and they removed or unhooked it.
That is according to my memory going back over 50 years...Here is the deal---When that black bulb is pulled out---that was what put it into the higher speed--now with the bulb pulled out the tractor will not move-----WHAT DOES THAT MEAN---Is the SHERMAN IN OR OUT OF THE TRACTOR??? Thanks len in Michigan
