Company Logo Shop Now
Re: Help with wheel seal parts-similar to Bearcats
Hidude
02-21-2021 14:51:02
Thanks rusty. Sure seal may have been some of my confusion. Beyond that I have the manual but im just not clear about it. Ford collectors site says 50-52 is the same parts. FO4 says there is a change at 486 serial number which would be in 52 I believe. So there is no option to isolate to grease only on the 8n? When the book says to grease pack the bearing thats just for initial lube but oil will always get to the outer seal? Thanks to all you guys for the info and knowledge you give to others.
Duner Wi
02-21-2021 16:07:21
 Re: Help with wheel seal parts-similar to Bearcats in reply to Hidude, 02-21-2021 14:51:02
This site sells parts and gives some measurements of seals that may help you. There is a serial # break and with your non matching engine you will have to figure it out with out serial #.
https://www.yesterdaystractors.com/cgi-bin/store/model_parts.cgi?SearchArea=Ford&&md=8N&cat=Drive%20Train&r=mcats
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
Latest Ad: 1967 Ford 3000 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
