Ford 9N, 2N & 8N Discussion Forum |
52 8N brakes and axle seals
Author |
[Modern View] |
Nw_bearcat
02-21-2021 13:00:17
Trying to get the parts I need ordered for a brake job, and while Im there, figured I replace axle seals also. Having troubles deciphering the parts sites to make sure I get all the right seals, and dont miss any. Its a 52. Does anyone have a list of all the seals I might need to knock this out when I get it to the shop?
nw_bearcat
02-22-2021 18:51:31
Re: 52 8N brakes and axle seals in reply to Nw_bearcat, 02-21-2021 13:00:17
Just swapped out my old transmission with the one I got from you. There must be some oil leaks in the inside of the old one. Its running well enough now, I may get motivated to tear the engine down and give it a fresh set or rings. Its funny, doesnt use oil, but has a fair amount of blow by. Starts good, pulls hard, just smokes out the breather. It had sat for a few years before I got it, Id sort of figured that it had a stuck ring, but also figured theyd work themselves loose, but not so far. I also bought another one. Supposedly the engine runs, but old guy got bored, and removed both the carb and the complete distributor, to rebuild them. Transmission Im not so sure about, but so far its contributing some good parts for the others.
Ultradog MN
02-23-2021 05:57:52
Re: 52 8N brakes and axle seals in reply to nw_bearcat, 02-22-2021 18:51:31
I have 2 sets of gas pistons for a 201 gasser here. Would let them go pretty reasonable. They came out of school tractors so were run but as you know they are essentially new. I have 3 decent tractors and likely won't buy any more. Would like to get rid of a sizeable stash of parts and put the $ into other hobbies.
Ultradog MN
02-22-2021 00:20:36
Howdy Tom. Glad to see you're still around. Did you get that SOS installed? I still have that filter for one. I couldn't find it for a long time, then found it. Think I could find it again. Would still send it to you if you want it. I did get the 8 sp and rear end put in my 4200. It's still not quite done. Needs the fenders put back on, white stripe on the hood, etc. but it's doing snow duty with a back blade this winter.
Nw_bearcat
02-22-2021 05:59:02
Re: 52 8N brakes and axle seals in reply to Ultradog MN, 02-22-2021 00:20:36
Yeah I did. Got that knocked out last March finally. It shifts really great now. My boy ran it on a IH5100 drill and planted all our cover crop rye last fall. After I pulled that transmission out of the one sos, I stood it on end, pulled the input shaft and sent it off to get rebuilt, and plans are to drag my grandpas 4000 in and do the same, or at least swap the shafts. It was split 10-12 years ago after it ate the clutch splines, and shaft was pretty bad then. It ate another clutch the spring of 2019 I think it was, so hopefully a shaft with new splines will run it on light duty for another few decades. That narrow front would be pretty handy to maneuver around with.
Ultradog MN
02-22-2021 06:11:00
Re: 52 8N brakes and axle seals in reply to Nw_bearcat, 02-22-2021 05:59:02
What did you do to make it shift better?
Nw_bearcat
02-23-2021 07:49:25
Re: 52 8N brakes and axle seals in reply to Ultradog MN, 02-22-2021 06:11:00
The transmission I got from you is a way better shifting unit than mine was. Im somewhat of the opinion that someone had been into it and done some work to it before you got it, but maybe it was just a low hour tractor. Since then, also picked up another one. SOS is a little suspect Ive learned, but isnt running. Old guy had removed the Distributor to keep in his basement so it didnt get stolen, and had removed the carb to take it apart and rebuild it. Havent found the motivation to start on it to see if engine actually runs. The one I put your transmission in runs, but smokes out the breather. Doesnt smoke out the exhaust to speak of (its a gas) but certainly puffs more than it should out that vent, or out the dipstick if you pull it while running. Doesnt really burn oil, and dont see it loose antifreeze. Starts good, and runs fine under a hard pull. It had sat before I got it a few years and had only gotten intermittent use before that, so I suspected a stuck ring, but after running it as I have, Im becoming doubtful its going to fix itself. Been trying to decide if I tear it down to put new rings in it, or take a chance on this other motor.
Hobo,NC
02-21-2021 16:50:10
BTW
late N inner seals 8N4233A-PAIR Axle gaskets I would get 10 # 9N43130 Years:1948-54 Gasket, Outer Axle gasket 8N4225 ( I don't use them I use good RTV) Years:1948-52 Gasket (Rear Axle Oil Seal) 8n4290 (I don't use them I use good RTV)
Hobo,NC
02-21-2021 16:35:01
The outer grease seal for either 48 to 51 are 51 up up are basically the same... Either will work. Whodathunk it...
The first design is a double lip the second a Sigle lip that's the only difference... I use the old retainer and replace the seals. Either will work.
Rusty2N
02-21-2021 13:33:15
This is what I did/do, got me a fo4 manual, read it. Best move I made is getting the Ford tractor Master parts catalog. 1939-1953. 9n, 2n, 8n, and naa. Shows every part and lists all the numbers. These books will be a life/time saver now and in the future. Good luck!!
Nw_bearcat
02-21-2021 15:36:01
Re: 52 8N brakes and axle seals in reply to Rusty2N, 02-21-2021 13:33:15
Reasonable. Im looking at parts books now, reading the fo4 book, and unless Im missing some pages, not sorting some of it out. Where Im struggling a little. Hopefully link works for reference #s Looks like at a minimum, should do 4248 and 4225. Likely should have a few 4229 for adjustments to side play. Questions I have... Do you tear down to replace 4233? Where in the assembly does 4284 go? Are there really 2 4251s used per side...one a part of assembly 4248, and one separately? I cant say that tractor actually leaking too bad, but figured if torn down that far, and it having never been to this point in 40 years, wouldnt be a bad exercise.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
1967 Ford 3000
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
