Re: Ford Prototype in reply to Den N Ms, 02-20-2021 13:54:04
One of my history books gives a brief description & pic of it trying to pull a plow. Test engineer said it drove about like a row boat in a hurricane. Henry's motto was "Lets start it up & see why it won't run".
Wow! I have never seen that or even knew it had been built. When I saw "prototype" I thought it was the tractor that sits in "The Henry Ford" in Dearborn next to Greenfield village.
Cold temperatures reduce the volatility of the air/fuel mixture. Heating the combustion chambers - ideally by heating the coolant that surrounds them, is the most effective cold weather starting aid. Nothing else comes close. I only have a couple of Ford diesel tractors. Below about 20 degrees they are pretty hopeless to get started unless I use starting fluid - which I am loathe to use. But if I plug in the block heater for an hour or two they will start like it's July.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor
... [Read Article]
Latest Ad:
Looking for an original IH 730 Plow Operators Manual. Not interested in a CIH reprint. Thank you
[More Ads]
