I have a 2N that sat for 8 years inside a garage with no lubricant in the rear differential or transmission. I have the engine running great, the PTO turns and the 3 point lifts and lowers.
My issue is that when maintaining a lifted load (mower) in a position, it sounds like the hydraulic pump is cavitating. The noise might be coming from something else but that is what it sounds like.
I am running just replaced Ford mineral oil 90 wt as recommended.
Any ideas? Hydraulic Pump Relief valve chattering? Like I said, the 3 pt lifts and lowers without hopping or stuttering. It's only when maintaining the lifted load in a position that the noise happens.
Thanks in advance for your reply.
