50 8N side mount.
Tractor started sputtering under load at full throttle while pulling a blade. Normally for this machine it is an indication the points are going. I replace the points and condenser and it wouldn't start. Saw some crud in the fuel bowl so I removed the bowl, cleaned it out and sprayed brake cleaner into the screen above the bowl. When I opened the fuel valve it filled the bowl quickly. My carburetor has a drain valve on the bottom and verified it drains briskly. Using the adjustable spark checker, no spark. Changed the condenser and verified gap of .025 and now it throws a good spark and started immediately. Next time I used it the sputtering returned. It would smooth out if I feathered the choke. Thinking I need to pull the carb and check the float needle and the jet for blockages. Sound like I'm on the right track?
