Grab the brass Ring (retainer)
WW2N
A while back the correct way to face the brass retainer over the
throttle shaft seal came up. Lots of ideas and thoughts of which was
right. This made sense to me and it may have been the way wires got crossed.
Untitled URL Link
That is a good video. I did purchase their throttle shaft seal kit. Fit as advertised. I understand where you are going with the valve guide seals but the primary job will be a valve job once you get into the machine. Much on this forum to help you with that! Find the thread that addresses removing the old valve guides. It is not as easy as the on-line videos make you believe!
