PTO shaft on 8n
(quoted from post at 23:47:19 02/09/21) Anyone have trouble getting the shaft back in after changing seal?
Sometimes, the new seal can make it a little more difficult to get slid back in. Just keep wiggling the PTO shaft to make sure you get the splines lined up. (Hope you don't have a nick or burr on the end of the shaft)
It acts like the shaft inside has slipped down. I can reach in
through the inspection panel and wiggle the teeth up but it
falls back down just a bit.
(quoted from post at 11:48:09 02/17/21) The seal is fine, its the splines will not mesh inside.
ay have to loosen the pump mount bolts so that it will align with the shaft better!
