The rod from the govenor to the carburetor has a spring loaded connector that fits over the ball on the throttle plate. It looks like a very small hitch. The spring that pulls the connector over the ball on the throttle has worn through the connector so the connector is not tight on the little ball.
Is there a way to repair this connector ? Can I buy a replacement connector ?
Would like to avoid replacing the whole rod as a unit if I can. Sorry if my terms are not correct .
Thank you in advance for any help you can give me.
