Ladies and gentlemen, I have a 1949, 8N. The issue is when I start it in cold weather the tractor starts fine. Letting it warm up the unit
moves freely. Problem is when I lower a rear blade to plow snow, if the tractor engine loads up slightly it will stall. If I can close the
choke fast enough I can keep it running, if not it quickly stalls, I use ethanol free gas in the tank . There is a slight miss while
warming up but this goes away. The carburetor has been rebuilt and I have tried to make some slight adjustments with no result. The other
thing the tractor can only be restarted when the throttle is in an idle position. Hope the readers can give me some idea as to what might
be going on. Regards Ray. Zamiska
