9-N,2-N parts?
old-9
As I am no longer restoring old iron, I am reducing my old parts. I have some 39-40 parts to dispose of. several castings- rear ends,ring gears,rear axles, and more. I have a complete transmission with straight gears with hyd pump. A steal hood snap in door(needs work), front axle (forward facing grease zerks) more than I remember right now. Would like to see someone that will be able to use and not scrap it. North central Indiana. joe email open.
I'll take the snap-in gas door; the small generator and Voltage Regulator; the 4-spoke steering wheel; the horizontal bar aluminum grille; the OEM Brass Sediment Bulb Assembly; the red dash IGNITION ON Lamp; 32" Hat Rims; chrome STANT rad cap; OEM early radiator; and OEM AMP and OIL gauges. Email is open
Tim Daley(MI)
Oops, I have the hood but not the door, the hood has rust where it connects to dash. No small generator. joe
