My oil pressure gauge glass cracked and I have replaced it with a new gauge. At the same time, I drained and replaced the oil, and put in a new filter and gasket. It always ran at 50 psi before but now it is glued to the top and the pressure is blowing oil out the gasket on the filter. I have tried reseating, and putting in another gasket. Can't get it to stop the massive leaking.
I have read in this forum that there is an oil pressure relief valve that might be stuck, but I can't find anything in my manuals that tells me where it is to check/fix. Can someone tell me where to find it? Also, since other than changing the oil, the only other change was replacing the oil pressure gauge, is it possible I did something wrong there or that the gauge is bad? Anything else I should check or could have done wrong?
Thanks.
Thanks.
