Ok so I dis assembled this engine block and ordered a complete rebuild kit. The new sleeves fit inside the old sleeves witch is not good, so them didn't work, now I can't find the correct ones. The top of the old pistons are stamped X695 and .083 Also not sure about the valves. Four of the valve guides are split guides and those valve stems are kinda like mushroom shaped on the stem. I do think these valves are the rotating ones.
The engine block serial number is 8N43512. Any help where I can get the complete engine rebuild kit for this tractor would be greatly appreciated.
