So, I had to change top covers and the used one I bought doesn't have witness marks for the lift arm position in the up position. The quadrant had witness marks but they are way off from my old one.. I set the quadrant slide adjustment at about center of the forward/back slot. Now I am trying to adjust the lift control arm and draft control. I got the position control spring set to 3.667 but couldn't get it to the spec of 3.5625. Close enough I think. The manual FO-4 says to position the lift arms at the witness marks in the up position so that the draft control spring can be adjusted. Since I don't have witness marks on the arms and top cover, does anyone know what the angle should be or another way to get the arms to the right position to adjust the draft control spring??
Thanks...
Thanks...
