So, now that I have the PTO shaft cut out, is there anything I should know in selecting a PTO shaft kit to install? I will go with the 1 3/8 inch conversion but just checking to see if there is anything else and if all the kit advertised are pretty much the same?
Also, I am taking the pump out to clean and/or rebuild. It looks like it might have been replaced or rebuilt some time in the past. It is pretty clean looking including on the bottom of the tractor. Any recommendations on what kit to use to rebuild it?
I will be finishing the top cover rebuild while I am waiting for the PTO shaft and pump parts but need to get them on order..
Thanks....
Thanks....
