So, I pulled my top cover tonight to put in a new lift cylinder and as expected I found other issues.
The lift cylinder was the old 3 ring type and I already have a new style piston and cylinder so no problem with this.
The lift arm shaft is loose and moves around so that means I need new lift arm shaft bushings. That seems straight forward.
The cam follower pin is worn I have one to replace it.
The cam is worn pretty badly so looks like I need a new lift ram arm. I can weld but not that good so just quicker and easier to replace it.
The control arm moves side to side (perpendicular to the center line of the tractor) as much as 1 1/2 inches. It looks like the pin it rides on is worn or the arm is worn at the pivot point. Is this movement normal or do I need a new control arm.
Two pictures attached. It appears the control arm is bent a little bit (one picture) and then the ram arm plunger sits sideways to the lift piston (other picture). Do I need to replace the control arm since it is bent and it has slop at the pivot point? Is it normal for the lift plunger to not directly align with the center of the piston?
Thanks...
[/img:2c9737c26d]
Thanks...
[/img:2c9737c26d]
