Company Logo Shop Now
Asked the neighborhood mechanic if he knew of anyone..
Red1
09-27-2020 14:40:15
That works on 8ns..as in installing a 12 volt conversion kit..He just
got back to me and said the guy he knew said to buy a kit on YT
and install it myself...a 2 hour job...so..
Are there good instructions here on how to do this..tia...
1Rustic1
10-03-2020 10:08:39
 Re: Asked the neighborhood mechanic if he knew of anyon in reply to Red1, 09-27-2020 14:40:15
Nothing like a 6 volt system when properly maintained..
trouttman
09-29-2020 17:44:38
I purchased the kit for my 2n from this sight about 3 years ago, no problems. Instructions in kit had wiring diagram and bracket mounting instructions. The hardest part is getting the new belt on the crankshaft pulley.
R Geiger
09-29-2020 12:14:30
Quoting Removed, click Modern View to seeThat don't compute!
Bob in Tennessee
09-29-2020 10:59:32
 Re: Asked the neighborhood mechanic if he knew of anyone.. in reply to Red1, 09-27-2020 14:40:15
I converted my front mount 8N to 12V and also changed to electronic ignition several years ago. I couldn't be more pleased. Starts quickly in all weather and runs better than it ever has for me. I would highly recommend.
Mad Farmer
09-29-2020 10:05:45
My 9N too. I plow snow winter time.
I only just had to replace the 6V coil and give the distributor a tune up after MANY years. But those were Ford parts, not Chinesium
HarryVanderpool
09-27-2020 17:28:01
I'm not against you doing what ever you want with your tractor.
But I just want to add....
We have lots and lots of farm equipment, company trucks, pickups, and newer cars.
NOTHING comes even close to starting as fast as our 6 volt 2N.
It's amazing. As soon as you barely hear the starter, it pops and runs.
Again; I'm not talking down what ever makes you happy.
Do what you want.
Red1
09-27-2020 16:30:45
Nothing really, that I know of. It's just I've heard the 12 volt
batteries are cheaper...more reliable...Better starting..
Indiana Ken
09-29-2020 19:02:21
 Re: Asked the neighborhood mechanic if he knew of anyon in reply to Red1, 09-27-2020 16:30:45
I have four 8-Ns, all 6 volts, all start when it is time to work. The last battery I purchased was in June of this year, from NAPA. The price was $75.12, net price was $51.99 to me. Add $9.00 if you do not have a core. I have a farm account with NAPA so no sales tax. I find the life of the 6 volt batterys are comparable to 12 volts. The life of a battery has everything to do with the charging system and keeping it caharged when not in use for a period time. The battery is the same, actually it has fewer parts to fail, 3 cells versus 6 cells for a 12 volt.....eh?
12 volts or 6 volts both work and it is a free country. Most important is doing the conversion correctly.
Red1
09-27-2020 16:28:02
Front mount...coil on top...generator left side..
Tim PloughNman Daley
09-27-2020 15:29:54
What's the matter with your 6V system?.
Tim Daley(MI)
HCooke
09-27-2020 15:10:26
The kit here on YT works well. Do not use the additional resistor. Does your 8N have a front mount or side mount distributor?
R Geiger
09-27-2020 15:08:18
I have done two on side mount 8n,s and easy to do. front mount dist I know nothing about!
HCooke
09-27-2020 15:11:53
 Re: Asked the neighborhood mechanic if he knew of anyon in reply to R Geiger, 09-27-2020 15:08:18
I did a front mount 9N. Worked great. Used a 12 volt coil - no need for the extra resistor they give you.
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
Latest Ad: 3 point drag arm for 420 HD crawler right side [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
