Broken Hi/Low Sherman Lever
8NChris
When an arm breaks does it typically break down inside? Saw this one online that appears the Sherman was removed.
(quoted from post at 06:32:54 09/27/20) Sherman was removed and hole was not plugged.
ishful thinking. So far the cheap tractors with the auxiliary transmissions are many hundreds or thousands of miles from me.
(quoted from post at 08:43:44 09/27/20)
hat tractor on Craigslist's was close in the Waco, Texas area.
Ill bet you the sherman is in there.
The handle came off.
If someone split the tractor to get the sherman,
They probably would not put it back together!
Joe
The hole was for a sherman combo. Some times a handle can come loose and can come off but unlikely. It could have be taken off. Typically they don't break inside and you should see
the square for the handle close to the end of the hole. If you don't see that it's likely, as Mike said, it was replaced with input shaft and not patched.
<a href="https://imgur.com/Qgjcny7">
Qgjcny7l.jpg" title="source: imgur.com"
</a>
I punched in ford in Farm & Garden on CL waco and couldn't find it. than punched in 2n and an F&T overdrive trans came up for $200
(quoted from post at 02:55:56 09/29/20) I punched in ford in Farm &amp; Garden on CL waco and couldn't find it. than punched in 2n and an F&amp;T overdrive trans came up for $200
https://dallas.craigslist.org/dal/grd/d/plano-ford-tractors-and-parts-come-see/7203320334.html
