Hello, I have a Ford 9N that that has me perplexed.
A few years back I converted it to 12 volts, added a Pertronix ignition, a remote 12 volt coil, new wires, plugs, cap, rotor and one wire 12 volt alternator. It ran great for a long time and after a while I garaged it to work on other projects. Ill also mention that it blows some blue smoke when transitioning from idle to full throttle. It has smoked like this going back to the 1980s.
Anyway, I took it out today after not running it for a year or so and it ran badly. It seemed like it wasnt firing on all cylinders. I removed each plug wire while it was running and found that cylinders two and four do not fire with the plug wires fully connected to the plug.
However, cylinders two and four fire perfectly with the plug wires barely attached such that the metal terminal end of the wire does not physically attach to the top of the plug itself. Essentially. the wire is arcing inside the rubber wire cap to the metal spark plug terminal.
It runs great this way, but as soon as I push the wire down against the plug terminal, the cylinder starts to miss.
Strangely, cylinder two fires with the plug wire lying next to the spark plug on the cylinder head flashing and arching across to the base of the plug.
Curious if anyone has experienced this and found a solution.
Thanks in advance for any advice.
