Jubilee Clutch Replacement - Remove Hydraulic Pump?
starguywisc
New User
I have to split my Jubilee and install a new clutch system. My question is will I have to remove the hydraulic pump to split it? If so will I'll need to order a pump gasket set when I order my clutch kit?
Thanks in advance.
(quoted from post at 11:55:46 09/25/20) I have to split my Jubilee and install a new clutch system. My question is will I have to remove the hydraulic pump to split it? If so will I'll need to order a pump gasket set when I order my clutch kit?
Thanks in advance.
No, just the hydraulic manifold lines. New O-rings there for re-assembly
Take the pump loose from the engine, and let it hang on the pipes, pulling it sideways a little. Probably not the best idea, but always worked for me. You will need a pump to engine gasket. EAF-911
