Put a new 6 volt coil on it a couple years ago...Helped the 'won't
start after turned off hot" ... problems...New battery a couple
years ago..Runs really well, it does lose oil pressure after a
half hour of bushhog...
So it started up yesterday ok..ran it for an hour bushhogging,
Turned it off and on half a dozen times..no problem...Went to
put it in the shed..stopped to pull the tarp back and it dies..
bang..dead..At that time I wasn't worried but thought it was
kinda abrupt..and I couldn't get it started...starter turned it over
ok until the battery started to run down..Ended up pushing it
into the shed..Put the float charger on that it always has hooked
up..This morning, deader than a door nail...mulit meter shows
24 volts across the posts...I'm not sure I'm reading it correctly.
Any ideas?...gas out the bottom of the carb ok..
