8n valve train
Trz
Im about to remove the valve train and Ive seen where people have used a modified screwdriver to stick in the exhaust port and hook onto something to compress the spring so you can remove the clip. I cant see anything to hook onto all I see is the valve stem. What am I missing?
(quoted from post at 11:55:58 09/22/20) Im about to remove the valve train and Ive seen where people have used a modified screwdriver to stick in the exhaust port and hook onto something to compress the spring so you can remove the clip. I cant see anything to hook onto all I see is the valve stem. What am I missing?
hat you are trying to do with the modified screwdriver is to push down on the valve guide so you can remove the clip!
I understand what Im supposed to be doing but I dont see the valve guide all I see is the valve stem going down through the block. You cant see the guide through the exhaust port, correct?
The guide is only accept through the valve cover?
I HIGHLY recommend Neway valve seat cutters.
I cut my valve seats and replaced the entire valve train on my 2N last winter.
Purrs like a kitten.
Thanks but, right now Im just trying to figure out how to compress the spring to remove them.
Ok, maybe I understand this now. The screw driver doesn’t actually
“hook” anything, it just pivots so it’s pushing down on the guide. Is
this correct?
(quoted from post at 14:02:52 09/22/20) Ok, maybe I understand this now. The screw driver doesn t actually
"hook" anything, it just pivots so it s pushing down on the guide. Is
this correct?
es that is correct.
Understand now. Bare with me I’m new at this and will have lots of questions. Thanks for all your help.
You push down on the valve guide that is if you are lucky and they are not stuck... It rare I get that lucky are have the time to un-stick them.
https://photos.yesterdaystractors.c...arameter=hobo,nc&w=pieces&cc=0&s=
Tool
Another way to do it fast as long as it has standard OEM valves if it has free rotating exhaust valves this may not work.
https://photos.yesterdaystractors.c...arameter=hobo,nc&w=pieces&cc=2&s=
When all else fails heat the spring with a propane torch while lifting up on the valve stem this will cause the spring to collapses you can then remove the keepers, valves then the spring. "TIP" plug the oil holes down thru the block so a keeper does now fall into the oil pan... Once the valves are out drive the guide out from the top side with a brass punch are steel tho steel may damage the guide to where its not usable... Its rare to see a good used guide they are throw away items...
My time is to valuable to fudge with it long new springs that you should buy anyways are cheap... : )
(quoted from post at 17:12:23 09/22/20)
Tool
Thanks this helps.
You better grab this.
They are getting harder and harder to find.
You're going to need it:
https://www.ebay.com/itm/Sioux-Flathead-Ford-Pilot-1-1-32-385-Top-Valve-Grinder-Seat-Grinder-85hp/174326715252?epid=1428087891&hash=item2896ae9374:g:MVIAAOSwDh1e8ja9
And no. I don't loan or borrow....
