What does it take to change this bearing ?
BradTN
As the title says... what is the proper way to change this bearing ?
This is the input on the transmission. It's been running on a galled up bearing race, so I think it may be damaged also. It won't come off by hand, of course, and I gently tried a small puller, plus heat, on it and that didn't do it.
So, you're saying I need to do a complete trans. rebuild ! Yikes ! The logic being...if one bearing is bad, others may be also ? That's not what I wanted to find out, bur it does make sense.
Apparently, there is a rebuild kit available ?
This trans. did have "Mud"(Oily,dirty water) in it when I first became it's care taker. I cleaned it out good back then(25+years ago), but the damage may have already been done.
