Company Logo Shop Now
What does it take to change this bearing ?
BradTN
09-13-2020 16:26:22
As the title says... what is the proper way to change this bearing ?
This is the input on the transmission. It's been running on a galled up bearing race, so I think it may be damaged also. It won't come off by hand, of course, and I gently tried a small puller, plus heat, on it and that didn't do it.
Hobo,NC
09-14-2020 04:28:43
 Re: What does it take to change this bearing ? in reply to BradTN, 09-13-2020 16:26:22
https://www.yesterdaystractors.com/Ford-8N_Transmission-Rebuild-Kit_TSBK3952.html
BradTN
09-13-2020 19:20:44
So, you're saying I need to do a complete trans. rebuild ! Yikes ! The logic being...if one bearing is bad, others may be also ? That's not what I wanted to find out, bur it does make sense.
Apparently, there is a rebuild kit available ?
This trans. did have "Mud"(Oily,dirty water) in it when I first became it's care taker. I cleaned it out good back then(25+years ago), but the damage may have already been done.
Hobo,NC
09-13-2020 17:04:15
You need to tear it down and get the other bearings also...That is the only bearing in the trans that will give you a fit, I have a tool that may get it without disassembly I doubt I would gamble the other bearings are not bad... A bearing kit price is not bad its not a bad job to do...
http://www.automedia2000.com/rsg/rsg0603a.htm
Copyright © 1997-2020 Yesterday's Tractor Co.
