Ford 8N original light housing with LED
Scott1ky
I’m looking at installing LED lights inside the original Ford 8N
housing canister. My tractor is 12 volts. I’ve found some 5-3/4”
lights at various sources online, but don’t know if the housing
depth at the center is an issue. Has anyone else been down
this road?
Thanks
Actually I did, got the lens and reflector on amazon for cheap.
Its a tight fit getting the clamp on but it will work, it's been a while since I put them together so I'll take another look at them tomorrow and post again to your question.... just getting the engine back together now.
I had another look at the headlight buckets today and got a measurement, there is 1-1/4 of space between the back of the bucket and back of the reflector.
There is a rubber cup that attached to the back of the reflector but its not in the pictures, I will have to be creative in getting a led bulb to fit but Im not too concerned about it now.
If you want the info where to get them let me know I had my nephew switch the original 6 volt generator over to 12 volt to retain the original look so not alot of amps available for halogens
