I put a rebuild kit in my 8N9510 carb. I reviewed all the posts I could find on how to re-adjust the carburetor.
I bench-set the adjustments as follows:
1. Idle speed screw, three turns inward after making contact with the post.
2. Idle mixture screw, 1 turn out from bottom.
3. Main mixture, 1 turn out from bottom (I know that some suggest two turns out, and leave it).
With the above settings, I needed to play with the choke (in/out), and the throttle lever to keep the engine running. When it warmed to operating temperature, the engine pulsed (sped-up, slowed-down constantly) by the governor. I could not get it to run at a constant RPM by adjusting the main mixture or the idle mixture.
At this point, I bought a new carb on Ebay. I set the adjustment screws/jets same as above with the very same result. No matter what I do with the idle mixture and the main mixture, I cannot get it to run at a constant speed.
Note that the governor was not causing the engine to pulse when the old carb was taken off (the old carb's needle valve was sticking causing the carb to flood and dump bas out the air intake, so the carb had to be dealt with...or I would have left it alone in the first place.
What am I doing wrong?
