solenoid and starter engages when it should not
oregonbob
New User
Hi. i have 51 8n stock (6volt) when I tighten the mounting nuts on the solinoid the starter ingages even when in gear or key off. any ideas?? when I loosen the nut it stops> wiring
is same as I have had for 10 years.
(quoted from post at 15:12:05 08/23/20) Hi. i have 51 8n stock (6volt) when I tighten the mounting nuts on the solinoid the starter ingages even when in gear or key off. any ideas?? when I loosen the nut it stops> wiring
ad solenoid, probably caused by twisting studs during tightening..
