The stock generator is putting out 7.5
AMPS. I am only showing 6 volts at the
battery terminal of the cutout.
I have a aftermarket generator that shows
25 AMPS at the generator. I'm only showing
6 volts at the battery terminal
I have polarized the system with every
testing.
I have run a jumper wire from the out put
post of the generator to the battery
terminal on the cutout. Nothing changes.
Jumper wire straight to the battery,
nothing changes.
I'm beginning to believe this tractor is
possessed.
All test are at and idle, and at 2/3
throttle.
I have read everything I can find on this
topic including the owners manual, the
archives here.
Thank You for your time.
testing.
nothing changes.
possessed.
throttle.
archives here.
