Company Logo Shop Now
Order Ford 8N Parts Online
Re: No start 8N PLEASE HELP
R Geiger
08-12-2020 10:24:36
bring number one cylinder up on compression stoke and see if you are seeing the timing mark. it should be at the 4 degree mark with the piston at tdc, then look to see where the rotor is pointed. Remember the 8n has two sets of timing marks on the flywheel. If the wrong set was used, you would have spark abut not at the correct time. Don't assume that you would have backfire problems, make sure it is right. not hard to do.
lha
08-12-2020 10:39:08
 Re: No start 8N PLEASE HELP in reply to R Geiger, 08-12-2020 10:24:36
I've done that on old engines myself. To check that theory,move the spark plug wires to number four where number one is now,then follow the timing order,1-2-4-3. If it runs,you've solved the problem,if not you've eliminated one possible cause. As Bruce[Va] stated,diagnose the problem before throwing money at it.
Jim L WA
08-12-2020 11:58:18
 Re: No start 8N PLEASE HELP in reply to lha, 08-12-2020 10:39:08
Good tip iha. I like that.
Copyright © 1997-2020 Yesterday's Tractor Co.
