2N-M5-MH30
New User
Hi
I want to remove the fenders----BUT the bolts are not budging....on this year the bolts go through the axle casting for the whole distance...6 inches...nuts loosen easily.
Any suggestions....I tried heating the cast but it is such a big heat sink.....used a rose bud torch...they wont turn 1/2 inch impact.
was thinking of grinding material on axle housing to expose bolt to apply penetrating oil....much like the new model axle housing....
I have the wheels off and the axles out for seal and brake work.
Look forward to hearing from you.
