Coil Continuity 8N front Mount
Have two "spare coils" for my 8N front mounted distributor. I get continuity when I connect top terminal to the "pig tail" on both but nothing on either when I connect top terminal with front tab. Are both of these coils bad? thank you.
(quoted from post at 11:09:29 08/11/20) Have two "spare coils" for my 8N front mounted distributor. I get continuity when I connect top terminal to the "pig tail" on both but nothing on either when I connect top terminal with front tab. Are both of these coils bad? thank you.
ig question is, what is continuity in your mind? On high voltage winding, you are looking at 15,000 Ohms, not one or two Ohms.
