Company Logo Shop Now
Order Ford 8N Parts Online
Re: ‘48 8n coolant Issue
Tim PloughNman Daley
08-11-2020 05:24:31
Fan belt tension is a good check for overheating issues but I don't understand your thinking on why you needed to set the distributor timing - one isn't related to the other. Did you install the distributor correctly with offset tangs and cam on engine? Back to the radiator. I think you should have taken the unit to a reliable radiator shop and have it boiled and tested there. How's your water pump? Time for a rebuild? You need a thermostat. BTW, model year is not important. All N's used the 4 PSI Radiator since '43.
THE N-NEWS; “KEEPING IT COOL” –by BRUCE HAYNES
The “N-NEWS” is published quarterly and subscriptions can be found at www.n-news.com or by mail at:
THE N-NEWS
9N-2N-8N-NAA NEWSLETTER
PO BOX 275
EAST CORINTH, VT 05040-0275
Tim Daley(MI)
Moab sun
08-11-2020 06:55:57
 Re: ‘48 8n coolant Issue in reply to Tim PloughNman Daley, 08-11-2020 05:24:31
Thanks for the feedback from everyone.
Regarding the timing, I've read in several places that retarded timing can cause overheating. The belt tension is good and the belt is the correct size. The water pump doesn't make noise, though I've not taken it off to see if the impeller is in good shape.
The thing I haven't figured out is why did the tractor run for close to an hour in extreme heat before boiling over and then after flushing the radiator and engine and then installing a thermostat and new coolant it started pushing out coolant within 5-7 minutes. And I wasn't able to put in more than 2 Gallons of coolant. something changed because of what I did and I'm stumped. The thermostat is facing the right direction. Is it possible it's just a bad thermostat? I might pull it out and run it to see if that changes things.
No doubt the radiator probably needs to be worked over and probably the ports in the engine need to be cleaned out. I'm learning that I should have done my homework better in this tractor before I bought it. :)
Copyright © 1997-2020 Yesterday's Tractor Co.
