I recently bought an 8n and it overheated a couple times
when it got over 100 degrees outside. I made sure the coolant
was just over the top of the radiator fins, tried richening the
mixture, ordered a jig to set the timing, made sure the belt had
proper tension. It didn’t have a thermostat so I figured it was a
good time to flush the coolant and install a thermostat with the
pointy end towards the radiator and installed close to the
engine block. I was able to only get a couple gallons of
coolant in so I figured I needed to run it long enough to open
the thermostat. After a bit of running time the fluid level rise
and it started pushing coolant out of the radiator. I checked
the upper hose and it was too hot to hold onto on both ends of
the hose. The lower hose was not nearly as hot. So it seems
my problem is worse than before flushing and installing a
thermostat. What am I doing wrong? Thanks for any help.
Oh- the temperature today outside was only in the low 90s
and the tractor was in the shade.
