Left Coast Geek
so I'm changing the radiator and hoses on my early 8N front distributor model... much as I've always done when I do this on an older car of mine, I ordered a new thermostat...
huh, there IS no thermostat in there now??
so, I put it in the top port on the head, with the pointy end towards the radiator, and the hose and water flow direction holds it in place? I'm assuming the coolant flows from the pump into the bottom of the radiator, then out the top and into the head?
