tractormuellerp
Changed the oil last week on my 8n ford. I replaced the oil filter and poured a little bit of new oil into the canister area, but put most of the 6 qts in the engine. As I was reading my operators manual it calls for adding a quart of oil into the canister. I assume I am fine, because the oil should get pumped up into the canister and fill itself, but I am a new to the maintenance world. Should I be okay? Or should I open back the canister and top it off?
Also I undid the drain plug on bottom of canister to drain oil out during my oil change. Is this the correct process? The canister didnt appear to be draining at all....
Thanks!
Thanks!
