Company Logo Shop Now
Order Ford 8N Parts Online
Re: Changed All The 8N Fluids, Home Testing Viscosity
TheOldHokie
08-06-2020 04:44:56
Quoting Removed, click Modern View to see Unfortunately there is a pretty low (high) limit on how much filtering you can realistically accomplish with a suction side filter. A 10u filter inhibits oil delivery rather substantially so to be safe you need to something like a 15 PSI bypass in the head and that winds up reducing the effectiveness of the filtering.
Hydraulic system OEMs usually go with a mesh strainer on the suction side and put the 10u filter on the tank return. Given the design of most old tractor systems there is no way to do that. The best solution I have found for N-series is a suction side strainer and a pump big enough to need a flow divider in the 3pt circuit. In those systems the excess flow goes back to the sump via an external circuit and you can put a full filter on that flow. Very similar to the engine oil filtering design.
TOH
Copyright © 1997-2020 Yesterday's Tractor Co.
