Company Logo Shop Now
Re: Tractor won t even turn over
Den N Ms
08-05-2020 13:21:16
Jdawg88,The start switch could be bad at the bottom of the steering column in the front . To test it You might try and jump the two terminals out of gear in NEUTRAL! with a old screwdriver and see if it starts or turns the engine over.No starter run,starter is bad if the battery is fully charged .
Jdawg88
08-05-2020 13:39:28
 Re: Tractor won t even turn over in reply to Den N Ms, 08-05-2020 13:21:16
I bought this tractor about 9 years ago and someone had converted the tractor to 12 volt and by-passed the push start with an ignition switch that has a start on it. I took the starter out and to hold it together I put nuts on the bolts, then I used jumper cables To see if it would work. It did quite well. I put it back in the tractor and now Iím trying to jump the starter in place but I donít even get a spark. Battery is charged, been checking it with a voltmeter. I put the jumper cables directly to the starter and not even a spark.... maybe Iíll pull it back out and try it again?
Copyright © 1997-2020 Yesterday's Tractor Co.
