Company Logo Shop Now
Front wheel
Kurtb
08-04-2020 15:55:11
Trying this again, can anyone tell me what parts Ill need to fix this? Does anyone ship overnight?
Royse
08-14-2020 06:52:40
 Re: Front wheel in reply to Kurtb, 08-04-2020 15:55:11
Kurt, I don't have a good way to ship, but I can check and see what
UPS would charge for it. My email is open on modern view if you
want to send me an email so we can discuss in person.
Kurtb
08-13-2020 21:11:13
Royse, would you be willing to ship to KS?
Kurt
Orion231
08-05-2020 12:45:53
I replaced mine with new ones from this site.. Everything went fine but there are bushings that probably need to be replaced as well.. I had a little difficult time getting them out with the bushing cutting tool I bought. Bushings and oil seals (dust covers) are also available here...
Tim PloughNman Daley
08-05-2020 04:46:50
Wow! Looks like the spindle shaft is broken off. How is that possible? The 9N & 2N use p/n 2N-3105(RH) and 2N-3105(LH). they are compatible with the 9N wheel hub as you show your BUDD WHEEL hub. Spindle don't cross with 8N ones BUT, you can replace the parts with 8N spindles then get a set of 8N 6 Bolt Pattern front wheel hubs. Tires are compatible, OEM are 4 x 19. New spindles at Just8Ns and Carpenter.
Tim Daley(MI)
Royse
08-04-2020 19:13:13
If you were close to me here in central Michigan, I have used ones.
Den N Ms
08-04-2020 16:52:08
Kurtb;Yes this one.
https://www.yesterdaystractors.com/Ford-2N_Front-Spindle_2N3106.html
Kurtb
08-04-2020 16:33:55
Thanks, Im assuming I need the 3106 spindle?
R Geiger
08-04-2020 16:20:24
seems i was wrong, this site sells them, at least for the 8n
R Geiger
08-04-2020 16:18:13
Used is the only thing you are going to find, couple on ebay now.
Copyright © 1997-2020 Yesterday's Tractor Co.
