Is there a rubber gasket on the air cleaner
grouser
I just put a new air intake on my NAA and the area that the hood meets the air cleaner I'm wondering if there's a rubber gasket in there to fill that small Gap. Thank you
I've had mine out a few times and I don't remember one being there. I'm pretty sure it's just metal to metal. That's where the unfiltered air is pulled into the cleaner so there's no reason to seal it.
There are two 2" rubber hoses used - do you mean those? One connects the air cleaner tube to the carb, one connects the air cleaner unit at the top. get out your Essential Manuals - required reading if'N ya wanna be an N Owner.
FORD NAA TRACTOR ESSENTIAL OWNER/OPERATOR/PARTS/SERVICE MANUALS:
FORD OEM NAA TRACTOR OWNER MANUAL:
CLYMER/I&T FO-19 SHOP REPAIR MANUAL – FORD NAA ’53-’54:
FORD TRACTOR 1939-1953 MPC:
FORD TRACTOR 1953-1959 MASTER PARTS CATALOG:
Tim Daley(MI)
(quoted from post at 12:46:10 08/02/20) There are two 2" rubber hoses used - do you mean those? One connects the air cleaner tube to the carb, one connects the air cleaner unit at the top. get out your Essential Manuals - required reading if'N ya wanna be an N Owner.
<center><img src="https://i.imgur.com/helTHXyh.jpg"></center>
CLYMER/I&T FO-19 SHOP REPAIR MANUAL FORD NAA 53- 54:
<center><img src="https://i.imgur.com/NtWeyGoh.jpg"></center>
<center><img src="https://i.imgur.com/q5zVwUyh.jpg"></center>
<center><img src="https://i.imgur.com/vzgJSv5h.jpg"></center>
Tim Daley(MI)
I could use a parts catalog that's for sure. No I'm not talking about the two round connecting rubber hoses. I'm talking about up at the top of the air cleaner where it matches up to the hood.
If you have a cyclone pre-cleaner then yes:
<a href="https://www.yesterdaystractors.com/Ford-8N_Cyclone-Air-Cleaner-Rubber-Seal_230055.html">https://www.yesterdaystractors.com/Ford-8N_Cyclone-Air-Cleaner-Rubber-Seal_230055.html</a>
If just the funnel, screen, and door, not.
