Tover's tractor
New User
To all { 8-N } specialist of vast experiences of a problem, which I have attempted to resolve with "NO" solutions! I've drained the tank , blew air thru it, installed the flow turn-valve, wide open, { only] to see the little bubbles appear to swan-dive in the little Float glass, then releases a portion of gas, down -line, to the end of the
gas line But, just a dribble !!???
I'm stumped as there is a small 5/6 nut 30 deg, from the flow turn wheel, which I toyed with "thinking" maybe a little Air-access to assist the air mix for the Flow-valve adjustment, may give a nice assist!!
Absolutely Nothing, and everything on the 8-N has been replaced, for any thoughts of poor -up-keep!! I've heard there is a secondary-cavity of fuel access in the Henry Ford - 8-N's but , do I need to purchase a new gas Tank, or just a new tractor? Argh ! :roll: Sure apprecaite a good suggestion or lesson in Gas & air!!?
