1948 8N, front mount.
I went out to mow with my 8N today. I took my "gas gauge" stick and inserted it into the gas tank...shocked to find no gas on stick at all...it should have been 1/2 full. Looked into the sediment bulb and it looked like there was gas in it. I figured I must have misjudged the amount of gas I had left in the tank. So, I opened the sediment bulb valve hoping it would start and have enough gas to get me to the outbuilding where I store my gas.
It started right up, but soon faltered and quit. I figured that I had run out of gas, so I carried a can of gas from the gas shed and poured it into the tank thinking it should start right up.
However, no go...acted like it was flooded. Upon examination, I found that gas was dripping from the carb, but I did not find
that the nut on the gas line was loose, nor the bottom bottom drain bolt seemed loose.
I took a screw driver and loosened the collar on the air inlet hose and gas poured out.
I have concluded that the valve on the sediment bulb must not be sealing (I always turn it all the way in when done with the tractor...without fail, not wanting gas to leak into the carb if the float were to stick.
I have also concluded that along with the sediment bulb valve must not be sealing, the float in the carb must be allowing gas to flood the carb and run out the air intake hose joint.
I can replace the valve stem in the sediment bulb, but am not sure what to do with the sticking float...or even for sure that is the problem.
Any insights on my problem? I am too old and decrepit to do much on the tractor, nor really interested in getting too involved due to my medical condition (I will need it for plowing snow this winter though), but I think I am up to at least changing out the sediment bulb valve...or should the whole thing be replaced?
