TheOldHokie
- Location
- Myersville, MD
I have been building N series auxiliary hydraulic kits for roughly 20 years and have used dozens of the 192160 crankshaft pulleys. If you look one up the product description will tell you there are 4 x 1/4-20 tapped holes in the face. That has been wrong for most of those 20 years. The holes have been tapped 1/4-28 for many years yet the descrptions were never corrected. So this AM I was putting together another kit and when I went to bolt the hub to the pulley I could not get the flat head cap screws started. WTF? Turns out this last batch of pulleys I got (from Reliable Aftermarket Parts) are now tapped M6. Naturally i did not have any M6 flathead cap screws so I wound up redrilling and tapping the holes. So if you buy a new pulley make sure you get some M6 screws in advance. I will order a box of a hundred for future use and will be well stocked if you happen to need a few.
Just another ripple in the sea of old tractor life.....
TOH
TOH
