Company Logo Shop Now
Re: Lift Cylinder piston
TheOldHokie
07-10-2020 03:27:01
The backup washer is used to support the oring against hydraulic pressure that pushes the edges of the oring into the gap between the piston and housing bore. This extrusion causes premature wear of the ring. The width of the oring groove is also increased to accommodate the backup washer and without it the oring will not get sufficient "squeeze" for the seal and the potential for damage from extrusion is increased even more than normal. Just a matter of time until it starts to tear and leak. How long is anyone's guess but it will not last as long as it should. If it were me I'd bite the bullet and fix my mistake - not a huge job or expense to make it right.
TOH
Copyright © 1997-2020 Yesterday's Tractor Co.
